Thread: I have $400 for an amp! HELP!! |
New member Username: Yamahaboy2123
Post Number: 8 Registered: Jul-04
| Posted on Monday, December 27, 2004 - 12:29 pm: |
ok here is the deal, i have $350-$400 to buy an amp at circuit city. i have to buy it from there cuz i got a gift card for like a hundred. i have http://www.bestbuy.com/site/olspage.jsp?id=1069299397134&skuId=6221064&productCa tegoryId=cat03081&type=product i know there not the best but there good for what im doing. i am going to make sealed box for them. also can i make those subs 2ohms??? also, if i make them 2ohms will i beable to put more watts to them?? thanks, Eric i was thinking this amp http://www.circuitcity.com/rpsm/oid/71253/originURLEncoded/http%253A%252F%252Fww w.circuitcity.com%252Frpsm%252FcatOid%252F-13095%252FN%252F20013088%252B20013095 %252B390%252Flink%252Fref%252Frpem%252Fccd%252Fcategorylist.do/rpem/ccd/productD etailReview.do#tabs its only 250 after rebates. |
Sean Haley Unregistered guest |
| Posted on Monday, December 27, 2004 - 03:28 pm: |
Try this P.O.S. amp for your P.O.S. subs...sweet life buddy...kill yourself http://www.circuitcity.com/ssm/ESA-2-Channel-Amplifier--EA250-/sem/rpsm/oid/9039 6/rpem/ccd/productDetail.do |
NorthWest,
Michigan
Post Number: 6962 Registered: Dec-03
| Posted on Monday, December 27, 2004 - 07:25 pm: |
forget bazooka. their amplifiers are horrible. you need 600 watts @ 4 ohms. my suggestion is to fihd a 2 channel amplifier rated for 150 watts RMS x 2 @ 4 ohms and bridge the amp to one channel. then make sure the amp has a low pass filter and set it to 80Hz. look at JBL, Kicker, and MTX for decent amplifiers CC carries. Alpine is another option as well. avoid audiobahn, dual, power acoustik, bazooka, and all the rest of the poor quality stuff that's dirt cheap for a reason.
