Thread: Remote turn on |
russell p Unregistered guest |
| Posted on Monday, December 27, 2004 - 10:00 am: |
i understand the rest of the installation but i don't know where the turn on goes |
NorthWest,
Michigan
Post Number: 6938 Registered: Dec-03
| Posted on Monday, December 27, 2004 - 12:06 pm: |
RTFM
| Posted on Monday, December 27, 2004 - 07:02 pm: |
where do i hook it up to the hu is what i mean |
NorthWest,
Michigan
Post Number: 6959 Registered: Dec-03
| Posted on Monday, December 27, 2004 - 07:05 pm: |
ah. depends on the head unit. aftermarket, look for a REM (remote) wire in the wiring harness diagram in the manual. if no REM exists, use the PWR ANT (power antenna) wire. If this is a factory OEM radio, you need to use a switched ignition wire, and the amp will be on when the car keys are in the ignition.
