Thread: Which amp to buy. GLasswolf please help a newbie |
New member Username: Sachinsoni
Post Number: 1 Registered: Dec-04
| Posted on Saturday, December 25, 2004 - 04:56 am: |
Hi Glasswolf/Other Gurus, I am in process of setting up my car audio system in my 99 Camry. I don't want anything too loud since I am not going to pound by subs really hard. Here is what I have bought: 1. MTX Thunder8000 10" subwoofer with a Ported with Vent subwoofer enclosure. Impedance of woofer is 4 ohms, 400RMS and 800 peak power. SUb has 2 1/2", high-temp, 4-layer voice coil. 2. I am looking to purchase an amplifier for this setup. I talked to a car installation guy and he suggested I go with a 4 channel amp, so I can use 2 channels to power my front speakers/tweeters and use the other two channels to power the sub. He said this would sound crisp and would be very clear since I wasn't looking for really big bass but just clear sound. What kind of amplifier would suit me. I am looking at an MTX304. Any suggestions as to what I should get?? Please help me. Also, would like to know what kind of wiring to get? P.S: I am using an Alpine 9815 head unit with factory speakers.
NorthWest,
Michigan
Post Number: 6890 Registered: Dec-03
| Posted on Saturday, December 25, 2004 - 12:38 pm: |
I'd look maybe at a Kicker KX600.4 or 800.4 the 800.4 would give you the full 400wRMS x 1 @ 4 ohms bridged for the sub, and 100wRMS x 2 for the fronts. If you go that route, I'd upgrade at least the front stage speakers to something rated to take that power, like some nice separates. you want a good front stage anyway. the 600.4 is 75x4 @ 4 ohms. the 800.4 is 100x4 @ 4 ohms
Post Number: 2 Registered: Dec-04
| Posted on Saturday, December 25, 2004 - 03:30 pm: |
FIrst of all wish you all a Merry Christmas. Thanks for your reply Glasswolf. I am looking to spend around $150-200 for the amp. I am hoping that I can get some nice deal on ebay for an older amp which I can use in my system, thats why I mentioned the MTX304 (http://www.mtx.com/caraudio/archive/thunder304.cfm). How is this one for my system? or the THunder 6304. OR maybe Glasswolf, you can give me the older Kickers whcih would suit my system so I can buy it used from someone, that would be great as well. And, which gauge wire do I use. What front speakers like you mentioned I should get? |
Post Number: 3 Registered: Dec-04
| Posted on Sunday, December 26, 2004 - 03:14 am: |
Please help.. Anyone.. Any links to cheap amps for my system, looking to spend around 150$ incl of shipping... |
New member Username: Metalgearsolid
NJ
Post Number: 6 Registered: Dec-04
| Posted on Sunday, December 26, 2004 - 03:24 am: |
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=64571%26item%3D5740038672 %26 this seems to solve your problem. price is $150. just 24 bucks for shippping.look at the spec. nothing to complain. |
Post Number: 4 Registered: Dec-04
| Posted on Sunday, December 26, 2004 - 03:52 am: |
Thanks for that Solid Snake, however this is a single channel. I was looking for a 4 channel amp and in any case is Audiobahn good?? I've read that Audiobahn is not a good amp.. Comments... Anyone? |
Post Number: 5 Registered: Dec-04
| Posted on Sunday, December 26, 2004 - 05:00 am: |
Also guys, what about a Kicker refurb. Check this out? http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem%26item%3D5739579200&fromMakeTrack= true Do you think Kicker refurbs are as good as their originals? What do you say? should I buy these or not?
Silver Member Username: Iamduff_87
Michigan
America!
Post Number: 297 Registered: May-04
| Posted on Sunday, December 26, 2004 - 02:28 pm: |
dont see the link. anyway audiobahn-not good. kicker-good. refurb should be alright. |
Gold Member Username: Jonathan_f
GA
Post Number: 2876 Registered: May-04
| Posted on Sunday, December 26, 2004 - 02:40 pm: |
The refurbs are just as good as the originals. Amps are done with circuit boards, they're pretty much modular besides simple external connections such as power wire and RCA connections. When you get a refurb'd amp, they're giving you a brand new amp in a used case, basically. |
| Posted on Sunday, December 26, 2004 - 02:44 pm: |
Thanks for the response guys. I guess I'm going with the kicker 800 just as Glass suggested. Glass also mentioned that I should change my front speakers since fs the real deal. What kind of speakers should I go for in the front. I'm looking for cheap and good quality.. Suggestions please.
NorthWest,
Michigan
Post Number: 6911 Registered: Dec-03
| Posted on Sunday, December 26, 2004 - 04:25 pm: |
infinity kappa or kappa perfect separates would work. the perfects are about $200 new on ebay. the kappas are less.
Post Number: 7 Registered: Dec-04
| Posted on Monday, December 27, 2004 - 02:25 am: |
Glass, What kind of power should I buy the Kappas for? I mean can you give me the specs of what to look for.
