Thread: Don't Laugh....need help with really old AMP |
| Posted on Friday, December 24, 2004 - 08:38 pm: |
Okay, this is what I have to work with.... US Acoustics 4050 (50x4) amp...yes, I know it is discontinued Sherwood XN-1000T crossover subwoofer (JL) in a box really old stuff....so any old school cats out there willing to give this Frankenstein project some much needed advice? How do I run power to the front speakers, the rear speakers and the subwoofer with this equipment? Head unit is an Alpine CDA-9827. |
Bronze Member Username: James1115
Ct
Post Number: 77 Registered: Dec-04
| Posted on Saturday, December 25, 2004 - 03:05 am: |
if you are planning on running your entire system off that amp I guess you would run your mids and highs off of two channels and run your sub off of two channels bridged! thats what I would think but ask Glass Wolf he will be able to help you out more. In my opinion I would use that amp for your mids and highs and get a seperate amp for your sub/subs! James |
NorthWest,
Michigan
Post Number: 6891 Registered: Dec-03
| Posted on Saturday, December 25, 2004 - 12:56 pm: |
well first, I need to know the impedance of that JL sub box. is it 4 ohms? if so, you can do one of the following: run the sub on the rear two amp channels, bridged, and run the front speakers from channels 1 and 2 of the amp, and rear speakers off the head unit's rear powered channels or, sub on the amp rear bridged channels and wire front and rear speakers to the front 2 amp channels in parallel. this will give more power to the rears but no ability to fade front to rear
