Home > Message Board > Car Audio > Amplifiers > Archive through December 29, 2004 > Amp
Author Thread: Amp
Username: Gball6
Charleston, IL
What size amp do i need for 4 12" Audiobahn Subs?
taylor17
What is the rms power on the subs?
Username: Gball6
Charleston, IL
400 watt RMS
Username: Glasswolf
NorthWest, Michigan
Post Number: 6771
you'd do fine with about 300 watts each so a 1200 watt amp (RMS) would do fine.
Username: Gball6
Charleston, IL
Is any brand better than the other? What about channels and ohms? Also where can i find a good deal?
Username: Gball6
Charleston, IL
I previously had this amp, but it got fried!! http://shop.store.yahoo.com/discountsonline/peteic22am.html
I really don't know what went wrong with it. Is this just not a good amp? What kind should i look for?
taylor17
Ya sum brand's are better than other's
rockford
orion
US amp's
True
Zapco, don't think I spelled that one right
Jl audio and a few others
What ohm's are your audiobahn's
taylor17
Also audiobahn makes good amp's
Username: Glasswolf
NorthWest, Michigan
Post Number: 6793
the channels, load, etc will depend on the subs you buy and how their coils are set up.
if you want to run 4 subs, you'll want each sub to be 2 ohms, or dual 4 ohm coils.
this will allow you to wire everything together for a single 2 ohm load.
then find an amp rated for 1200wRMS x 1 @ 2 ohms
a few examples:
JBL BP1200.1
Kicker SX1250.1 (I think.. may be @ 1 ohm for this one)
JL Audio 1000/1
MTX Thunder1501D (I think that's the model)
Orion 1200D
really whatever fits your budget and has that power rating.
Username: Gball6
Charleston, IL
These are the speakers i have. http://www.acaraudio.com/product_info.php?manufacturers_id=41&products_id=1010
Should i still use a 1200 watt amp?
taylor17
Ya just get a amp that put's 1200 watt's "rms" at 2 ohms
Username: Glasswolf
NorthWest, Michigan
Post Number: 6803
yeah. they are dual 4 ohm coils.
you want the amp to deliver 1200 watts RMS x 1 @ 2 ohms
Home > Message Board > Car Audio > Amplifiers > Archive through December 29, 2004 > Amp [ « Previous ] [ Next » ]
