Thread: Need some help please |
Bronze Member Username: Ginuwinepz
Post Number: 27 Registered: Aug-04
| Posted on Wednesday, December 22, 2004 - 05:45 pm: |
hey, i just bought a brand new 4 channel amp for my full range....well when i change tracks on my cd player, the amp goes into power protect and i have to turn my cd player off then back on again to hear the song, sometimes it does not do this, but most of the time it does can some one please help me?? |
NorthWest,
Michigan
Post Number: 6732 Registered: Dec-03
| Posted on Wednesday, December 22, 2004 - 05:58 pm: |
check your wiring for the amp. sounds like it may be a bad ground. should be to bare chassis metal with the same gauge wire as the power line
Post Number: 30 Registered: Aug-04
| Posted on Wednesday, December 22, 2004 - 08:24 pm: |
ok, i will be sure to check my ground wires and everything as soon as my girl gets back with my car! |
Post Number: 34 Registered: Aug-04
| Posted on Friday, December 24, 2004 - 05:48 pm: |
Hi, I just checked my grounds and everything seems be ok. i have no idea what is wrong, it pretty much only does it when i switch songs on the cd player, or when i switch to tuner. |
NorthWest,
Michigan
Post Number: 6898 Registered: Dec-03
| Posted on Saturday, December 25, 2004 - 01:17 pm: |
maybe a bad head unit, or wiring issue with the head unit then.
