Thread: System |
Bronze Member Username: Djeter108
IN
Post Number: 35 Registered: Nov-04
| Posted on Tuesday, December 21, 2004 - 03:20 pm: |
i have an unexpected influx of income, and I was looking for any suggestions. I have about 3 grand to spend on just subs, box, amp, etc. already have head unit, speakers. any suggestions? i want to break some ribs in my car... civic, small trunk but i dont care. |
IN
Post Number: 36 Registered: Nov-04
| Posted on Tuesday, December 21, 2004 - 03:30 pm: |
how does memphis audio sound? diamond audio? i can get a custom box that will fill my trunk so i can fit two 15s
Bronze Member Username: James1115
Ct
Post Number: 50 Registered: Dec-04
| Posted on Tuesday, December 21, 2004 - 09:47 pm: |
why dont you try 2-jl 13w7's with a jl 1000/1 to each, or US amps DE 1000 to each. I am sure you would prob be happy with that set up. Also try REXXX 15's with the same amps as above. I mean hell if you got the money why not! The nice thing is with either set up you can run at 1ohm or 1.5ohms's with the W7's and utalize peak power from your amps. Both those amps are stable at 1ohm so you would be fine. |
NorthWest,
Michigan
Post Number: 6722 Registered: Dec-03
| Posted on Wednesday, December 22, 2004 - 04:49 pm: |
Two RE triple X 12" or 15" subs with an Orion 1200D on each one. zapco reference or a matching orion 4 channel amp for components 1/0ga power distribution 200A alternator for the civic from ebay yellow top battery spend the remainder on the box for the subs and an alarm system
IN
Post Number: 37 Registered: Nov-04
| Posted on Wednesday, December 22, 2004 - 05:38 pm: |
thanks, also for a friend. is a Diamond Audio TDX 12D4 better than a Kicker L7 (both 12 inches) |
NorthWest,
Michigan
Post Number: 6734 Registered: Dec-03
| Posted on Wednesday, December 22, 2004 - 06:04 pm: |
the diamond is better constructed, and far better for SQ. the kicker would probbaly be louder if that's your only goal, but it won't sound as good doing it.
IN
Post Number: 38 Registered: Nov-04
| Posted on Wednesday, December 22, 2004 - 06:16 pm: |
ok thanks. i went to a sound place today. for 3 grand i can get 2 12" TDXs, a memphis mojo amp (the 3000 bridged mono one), a kinetik power cell (heard amazing things abt it), a setup in the trunk that will like custom fit the subs INTO my car, and a car alarm system that gives me power door locks, remote start, and a pager that tells me when and where my car has been jacked .... all for 3 grand. not to mention lifetime installation warantee, and 5 years on all the parts. sound good? |
IN
Post Number: 39 Registered: Nov-04
| Posted on Wednesday, December 22, 2004 - 06:19 pm: |
and whats the trade in on a 2004 L7 12" 2 ohm, used for two months? and a Boss Audio Riot 1600 watt amp? if u could just direct me to a website, i'll find it myself. oh, and i can't actually fit a 15 in the back of my trunk. it's just over 16 inches tall. |
IN
Post Number: 40 Registered: Nov-04
| Posted on Wednesday, December 22, 2004 - 06:21 pm: |
sorry, just read my earlier post, probably should have specified what i meant by "better". thanks for the answer, too. |
IN
Post Number: 41 Registered: Nov-04
| Posted on Wednesday, December 22, 2004 - 06:40 pm: |
i feel bad abt chain posting, but i keep remembering things. as of now i have no tweeters. my music is mostly limited to rap with the occasional green day or the like. should i invest in some, or is it not worth it. |
NorthWest,
Michigan
Post Number: 6752 Registered: Dec-03
| Posted on Wednesday, December 22, 2004 - 07:08 pm: |
sounds like a sweet system. I'd go with component separates up front. that'd liven up the front stage a lot. give a better overall sound to the system compared to focusing on the subs and not the rest of the system
IN
Post Number: 43 Registered: Nov-04
| Posted on Thursday, December 23, 2004 - 12:23 am: |
im already running new kicker speakers in my doors and in my back pannel, and the HU is new too (two months) |
NorthWest,
Michigan
Post Number: 6766 Registered: Dec-03
| Posted on Thursday, December 23, 2004 - 12:36 am: |
then just amplify that front stage and maybe the rears and you'd be all set
IN
Post Number: 65 Registered: Nov-04
| Posted on Friday, December 24, 2004 - 10:55 pm: |
Okay. I asked this question in another thread but I can't find it. I used to be able to find my last 20 some posts through my profile, but I can't find it now. Should I get tweeters if the majority of the music I listen to is rap, with the occasional Green Day? |
IN
Post Number: 66 Registered: Nov-04
| Posted on Friday, December 24, 2004 - 10:57 pm: |
Wow, the post I was talking about is right only a few up. |
IN
Post Number: 68 Registered: Nov-04
| Posted on Friday, December 24, 2004 - 11:57 pm: |
Oh and is the HO alternator necessary if I'm getting the kinetik power cell? |
NorthWest,
Michigan
Post Number: 6896 Registered: Dec-03
| Posted on Saturday, December 25, 2004 - 01:12 pm: |
I don't see any need for separate tweeters if you have good separates up front already. the alternator is needed if your lights dim, or voltage drops.. otherwise, no.
