Thread: Wiring question |
New member Username: Rc_raycer
Post Number: 2 Registered: Dec-04
| Posted on Monday, December 20, 2004 - 01:29 pm: |
Will a sub sound the same whether it is wired into 2 or 8 ohm operation. |
Silver Member Username: Carguy
Post Number: 906 Registered: Nov-04
| Posted on Monday, December 20, 2004 - 02:36 pm: |
That'll depend on the amp. Most car amps will operate better at 4ohms, not 8ohms. As you go lower in ohms, the output power will increase. However, do not exceed the amp's limit.
Silver Member Username: Oleg
Santa Monica,
CA
Post Number: 200 Registered: Nov-04
| Posted on Monday, December 20, 2004 - 04:56 pm: |
For subs, 2ohm is good. |
NorthWest,
Michigan
Post Number: 6679 Registered: Dec-03
| Posted on Monday, December 20, 2004 - 10:41 pm: |
the impedance will affect the amount of power the amplifier supplies to the speaker(s).
