Home > Message Board > Car Audio > Amplifiers > Archive through December 22, 2004 > Kicker kx 1200.1
Author Thread: Kicker kx 1200.1
Username: Basketballinu05
ok i have bought 2 kicker 10" L7 subs and i am pretty new to all of this and i am wondering if the kicker kx 1200.1 will power both subs up to or pretty close to their full capabilities.
thanks
Username: Glasswolf
NorthWest, Michigan
Post Number: 6669
that depends on the coil configureation for the subs
dual 4 ohm voice coils
Username: Glasswolf
NorthWest, Michigan
Post Number: 6676
then that amp is a great choice
ohh....but are you sure 1200 watts is enough to power both of the L7's to their full capability?
Username: Glasswolf
NorthWest, Michigan
Post Number: 6708
yes
thermal power handling and the amount of power needed to reach full excursion are very different things.
"power handling" is a measure of the ehat the coils can handle without thermal damage.
that's all.
Home > Message Board > Car Audio > Amplifiers > Archive through December 22, 2004 > Kicker kx 1200.1 [ « Previous ] [ Next » ]
