Thread: Need help GlassWolf! or anyone! |
New member Username: Trojanmanms
Post Number: 7 Registered: Dec-04
| Posted on Sunday, December 19, 2004 - 11:56 pm: |
I have a 500W RMS MM12 polk audio sub. I am looking into buying an amp. Pretty set on the Sony Xplod http://www.goodguys.com/adtemplate.asp?invky=395876 it gives off 500W power bridged. I have a headunit that has a preamp out. Does that do me any good? or do i need to buy a new headunit to make it work? |
Bronze Member Username: Terminatermule
Australia
Post Number: 62 Registered: Nov-04
| Posted on Monday, December 20, 2004 - 12:20 am: |
mario don't buy a sony amp man. They are total rubbish. If you buy a sony amp there is a good chance that it will do just as the name implies and explode. lol. Later man |
Silver Member Username: Carguy
Post Number: 899 Registered: Nov-04
| Posted on Monday, December 20, 2004 - 09:55 am: |
Yo Mario, if budget is tight, then try looking at MTX6500D. It's cheap on eBay. Sony does have some advantages. If you live in a cold climate, use it as a heater for your trunk! One more thing, don't get fooled by Sony's marketing scam. They might've been the first to use peak power instead of rms. If you're lucky, you'll get half of the stated "useable" power. |
NorthWest,
Michigan
Post Number: 6649 Registered: Dec-03
| Posted on Monday, December 20, 2004 - 09:58 am: |
or even a JBL bp600.1 anything but that sony they have the highest failure rates of any company I can think of in car audio. save yourself the headaches and avoid sony anything for cars. trust me. they blow.
Post Number: 8 Registered: Dec-04
| Posted on Monday, December 20, 2004 - 01:02 pm: |
thanks guys, but that still doesnt really answer my question about the headunit and wiring. does having a preamp out do anything for me? or do i need a new head unit? |
Post Number: 903 Registered: Nov-04
| Posted on Monday, December 20, 2004 - 02:27 pm: |
The preout rca connectors will work with any amp. You don't need a new HU unless you want dvd and surround sound feature.
Post Number: 9 Registered: Dec-04
| Posted on Monday, December 20, 2004 - 11:16 pm: |
you guys both recommended amps that delivered 250W at 4 Ohms. My sub is 500W RMS at 4 ohms. Do you really think that these amps will deliver enough power? |
Post Number: 915 Registered: Nov-04
| Posted on Tuesday, December 21, 2004 - 09:17 am: |
Is your sub 4ohms DVC or 2ohms DVC? |
NorthWest,
Michigan
Post Number: 6688 Registered: Dec-03
| Posted on Tuesday, December 21, 2004 - 10:00 am: |
you need to specify the coil configuration of your speakers when asking for suggestions on an amp. that affects the amount of power the amp will deliver.
Post Number: 10 Registered: Dec-04
| Posted on Tuesday, December 21, 2004 - 01:27 pm: |
i think you mean dual voice coil by DVC. Right? Well, my sub i believe is single voice coil at 4 Ohms. In that case, will the 250W amps you and issac suggested work? |
NorthWest,
Michigan
Post Number: 6707 Registered: Dec-03
| Posted on Tuesday, December 21, 2004 - 07:11 pm: |
if you have a single 4 ohm coil sub, you'll need an amp that supplies: 500wRMS x 1 @ 4 ohms mono or 500wRMS x 1 @ 4 ohms bridged (2 channel) it'll be cheaper to find a 2 channel amp rated for bridged power. it'll be around 125wRMS x 2 @ 4 ohms
