Home > Message Board > Car Audio > Amplifiers > Archive through December 22, 2004 > Rft1000bd amp stable at 1ohm?
Author Thread: Rft1000bd amp stable at 1ohm?
Username: Rachellboo
Chicago, Illinois
Usa
i have a rockford fosgate t1000bd (2004 model) amp on 2 L7 kickers at 2ohms but it's not hitting as hard as id like it 2. should i try 1000 watts at 1ohm? or will it shut off over time?
Username: Glasswolf
NorthWest, Michigan
Post Number: 6612
read the manual and see if it's stable to 1 ohm.
see if your car's charging system can handle the current draw if the amp is 1 ohm stable.
then figure out how you'd get a 1 ohm load from those two subs on that amp, if it's a 2 ohm load now.
Home > Message Board > Car Audio > Amplifiers > Archive through December 22, 2004 > Rft1000bd amp stable at 1ohm? [ « Previous ] [ Next » ]
