Home > Message Board > Car Audio > Amplifiers > Archive through December 22, 2004 > Speaker level inputs question for Gla...
Author Thread: Speaker level inputs question for GlassWolf
Username: Jryan1888
If I run wires from my rear speakers to my amp that can handle speaker level inputs, will it take away power from my rear speakers to where I will hardly be able to hear them.
Username: Glasswolf
NorthWest, Michigan
Post Number: 6609
it shouldn't, no.
tapping into the rear speaker lines should just get the signal that way, allowing you to run your rear speakers as normal, and run subs from the amp by getting the input signal from those lines you tapped into.
Username: Jryan1888
I am going to power 2 12" subs from my amp, should I tap into both rear speakers?
Username: Glasswolf
NorthWest, Michigan
Post Number: 6618
read the manual for the amp.
Home > Message Board > Car Audio > Amplifiers > Archive through December 22, 2004 > Speaker level inputs question for Gla... [ « Previous ] [ Next » ]
