Thread: Help w/ Crossovers |
New member Username: Jpap2369
Post Number: 1 Registered: Dec-04
| Posted on Sunday, December 19, 2004 - 10:32 am: |
I am new to the car audio stuff but I know a little about some of it. Well i was wondering if anyone could help me with a crossover issue. I have an amp that has both high and low crossovers. I have no clue where I should set them for maxium performance. The amp is an American Legacy LA1990 which has two channels. I have two Diamond Audio CM3 12's with dual 4-ohn voice coils. I have wired them to the amp so there is a 2-ohm load to each channel (one sub per channel). I am just wondering if anyone out there would know where to set the high and low crossovers. Thanks. |
Post Number: 2 Registered: Dec-04
| Posted on Sunday, December 19, 2004 - 10:37 am: |
I forgot to add. I'm low on money and am not intrested in buying a better quality amplifier. |
NorthWest,
Michigan
Post Number: 6595 Registered: Dec-03
| Posted on Sunday, December 19, 2004 - 11:23 am: |
set the crossover to low-pass *LPF) and if you can set the frequency, set it to between 60-80Hz. that should do the trick
Post Number: 3 Registered: Dec-04
| Posted on Monday, December 20, 2004 - 09:16 pm: |
Thanks man |
