Thread: Please help me pick out an amp |
New member Username: Yamahaboy2123
Post Number: 6 Registered: Jul-04
| Posted on Saturday, December 18, 2004 - 03:27 pm: |
I have these subs http://www.bestbuy.com/site/olspage.jsp?id=1069299397134&skuId=6221064&productCa tegoryId=cat03081&type=product yes i know there not the best but there fine for what im doing....i just have them hooked up to my surround sound in my room now with a 280w ht sub amp. i was looking at this amp http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=4950%26item%3D5737150321% 26#ebayphotohosting how is it? what other sujestins do you have. i was looking at the jbl 1200.1 but on cardomain.com there always sold out and they have the best price....go figure but ne help would be great thanks, Eric |
Post Number: 7 Registered: Jul-04
| Posted on Saturday, December 18, 2004 - 03:29 pm: |
i forgott to say that im going to be making a sealed box for those subs. i mostly listen to rap,rock,pop n all of that |
Silver Member Username: Oleg
Santa Monica,
CA
Post Number: 204 Registered: Nov-04
| Posted on Monday, December 20, 2004 - 11:21 pm: |
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=64571%26item%3D5739029371 %26 or http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=18797%26item%3D5739035853 %26 Try to rewire the subs to get less resistance so you can get more out of the amps... |
Silver Member Username: Solacedagony
New Jersey
US
Post Number: 159 Registered: Oct-04
| Posted on Tuesday, December 21, 2004 - 02:55 pm: |
I'd say go with that MTX amp, but be careful cause those subs probably aren't going to take as much power as that amp will give them. A sealed box will sound much better than that cheap bandpass. Also, make sure you know how to wire those. If you need wiring diagrams, check out www.rockfordfosgate.com. It's also hard to tell from their product description the impedance of the coils on the subs. Can't tell if they're two 8 ohm SVC subs giving it a 4 ohm impedance or the subs themselves are 4 ohm SVC subs. If it doesn't say on the sub, you may need to check it with a multimeter. If you can't do that, see if you can find a model or serial number to type into google. Try to wire it to 2 ohms if possible. If not, 4 ohms will work. The MTX doesn't support 1 ohm, I don't think, not sure about the Audiobahn. If you have any questions, feel free to post. |
Santa Monica,
CA
Post Number: 207 Registered: Nov-04
| Posted on Tuesday, December 21, 2004 - 07:04 pm: |
I think they're 2 ohm SVC ran in series? With only 1 connection available, so a review said. Well, open it up and see what you've got. |
Silver Member Username: Jmloughrey
Farmington,
CT
Post Number: 625 Registered: Jul-04
| Posted on Tuesday, December 21, 2004 - 07:21 pm: |
the thing is that whole box is 600rms of power, not each sub. If you use that JBL amp you'll destroy those subs in a matter or minutes (more like seconds). Find an amp that does about 500x1 @ 2 ohms and you should be all set. The JBL 600.1 would probably be a better fit for that system. Yahoo search for your amp at another place, sounddomain.com's prices are a touch high, ebay it and you'll save a whole bunch of money. |
