Home > Message Board > Car Audio > Amplifiers > Archive through December 22, 2004 > Help installing an AMP Please
Author Thread: Help installing an AMP Please
Username: Jmiller
I'm getting ready to install a 50x4 AMP to push 4 60RSM 6 1/2 speakers. First I'd like to know what wire gauge should I use to wire the speakers to the AMP? Second, I got my hand on the wiring information for my car, 04 Accord, but there is not AMP turn-on wire coming from the HU. Where else do I get a source for the 12v turn-on wire for the AMP.
Thanks.
Username: Jmiller
Post Number: 7
I see that there is a (+) power antenna wire. MY car does not have a power antenna. Can this line be use to turn-on the AMP?
Username: Xxkmfdmxx
Saint Petersburg, FL
Post Number: 123
Is it a stock HU? Most if not all Aftermarket Headunits have the Power antenna wire.
Username: Xxkmfdmxx
Post Number: 124
CarAudio And PC
That + Power Antenna can be used as the Remote Turnon for your AMP. It works just the same, and puts out 12V.
Username: Jmiller
Post Number: 8
What wire AWG should I use to connect the Speakers to the AMP?
Username: Glasswolf
NorthWest, Michigan
Post Number: 6577
16ga is plenty for components
14ga is good for subs
Home > Message Board > Car Audio > Amplifiers > Archive through December 22, 2004 > Help installing an AMP Please [ « Previous ] [ Next » ]
