Thread: Wiring ohms |
New member Username: Robby_
Post Number: 8 Registered: Dec-04
| Posted on Friday, December 17, 2004 - 05:24 pm: |
if i have a 15" dvc sub and want to run the coils in parrelel how would i hook it up. my sub is ma audio 15" 800 w rated at 4 ohms i think ( how do you set or tell the ohms in a sub) and i am running it off a alpine v 12 100 with 150 w rms at 4 ohms what would be the best wasy to wire it up and what ohms should i run it off of 2 4 or 8 i know this is underpowered but how can i set it up to produce the most bass and good sound quality thanks |
Bronze Member Username: Dnizzle
Raleigh,
NC
Post Number: 33 Registered: Nov-04
| Posted on Friday, December 17, 2004 - 06:01 pm: |
If its dvc you can run it at 2 or 8- if not then 4- but there are a ton of wiring tutorials on the internet |
Bronze Member Username: Napalmz
MIDWEST
Post Number: 60 Registered: Oct-04
| Posted on Friday, December 17, 2004 - 06:24 pm: |
MIDWEST
Post Number: 61 Registered: Oct-04
just make sure your amp is 2 ohm stable |
Post Number: 9 Registered: Dec-04
| Posted on Friday, December 17, 2004 - 09:54 pm: |
do both the coils have to be conected like that or can you runa a parellel circut with one coil just conected to the other thanks |
