Home > Message Board > Car Audio > Amplifiers > Archive through December 22, 2004 > Alpine v 12 100
Author Thread: Alpine v 12 100
Username: Robby_
i have an alpine v12 100 and it has no markings or ratings on the back i was wondering if any one knew the stats or any info on this amp. as well as if it would work with a 15" ma audio sub 800 watts max power
thanks
bluntman420
Amplifier Type: Mono
RMS Power: 100W x 1 @ 12V
THD at 4-Ohm RMS Power: 0.08%
RMS Power: 150W x 1 @ 12V
Speaker Level Inputs: Yes
Preamp Outputs: No
Built-In Crossovers: LP
Bass Boost: 12 dB
Frequency Response: 20-200 Hz
Signal to Noise Ratio: 100 dB
Fuse Rating: n/a
those are for the mrv-100m.....is that what you wanted?
bluntman420
Preamp Outputs: No
Bass Boost: 12 dB
Fuse Rating: n/a
mrv-100m...is that it?...and if thats it you might wanna get rid of that one and buy another one.
Username: Robby_
thanks alot
Home > Message Board > Car Audio > Amplifiers > Archive through December 22, 2004 > Alpine v 12 100 [ « Previous ] [ Next » ]
