Home > Message Board > Car Audio > Amplifiers > Archive through December 22, 2004 > Alternator?
Author Thread: Alternator?
Username: Rzarector
Coquitlam, Bc
Post Number: 30
is it true when you upgrade to a higher amperage alternator -200's u need a different belt/pullies to turn it? aparently i need to get a 9 tooth belt or somethin instead if the one i got
Username: Jonathan_f
GA
Post Number: 2773
Sometimes you do, but usually the alternator manufacturer will at least provide a pulley that will work with the belt you have. Sometimes HO alternators come with smaller pulleys so that they turn faster with the RPM of the car.
Home > Message Board > Car Audio > Amplifiers > Archive through December 22, 2004 > Alternator? [ « Previous ] [ Next » ]
