Home > Message Board > Car Audio > Head Units > Archive through March 16, 2004 > New Alpine problem!!!
Author Thread: New Alpine problem!!!
Username: Wdlong1
I just had new Alpine HU 9811 installed and rear speakers do not work with CD play. They work fine with tuner.
Also I have a powered sub connected via RCA. I am sure this is a simple problem, I just need help fixing it.
Thanks.
Username: Glasswolf
Post Number: 1002
was it installed professionally?
take it back.
apparently someone grounded the speakers using the power antenna lead or something.
The 9811 is just wired incorrectly.
Username: Wdlong1
Yea, took it back and that was exactly the problem.
Thanks for your help.
Username: Glasswolf
Post Number: 1011
good unit.
you'll get a lot of good use out of it.
Home > Message Board > Car Audio > Head Units > Archive through March 16, 2004 > New Alpine problem!!! [ « Previous ] [ Next » ]
