Thread: Over current light stays on |
New member Username: Nate232323
Post Number: 4 Registered: Dec-04
| Posted on Monday, December 13, 2004 - 02:22 am: |
i have a sony explode xm1502sx and when it's conected the over curent light turns on when you turn on the power. the light stays on even when the amp is disconected from the sub and the inputs i have 2 10 rockford phosgate punch's that i want to run on it. is the amp fried or is this a problem that can be fixed |
New member Username: Help_2
MN
Post Number: 8 Registered: Dec-04
| Posted on Monday, December 13, 2004 - 02:34 am: |
Check the other connections first... but most likely its fried. |
Post Number: 5 Registered: Dec-04
| Posted on Monday, December 13, 2004 - 03:11 am: |
i used a different amp an old mtx rt 2120 and it all plays fine their is a signal from the head unit and coming out of the amp so does this mean the amp is toast? if so can you fix it or should i throw it out |
Post Number: 6 Registered: Dec-04
| Posted on Monday, December 13, 2004 - 03:12 am: |
when i tried to use the sony one agoin the power light doesn't even come on any more only the over current light is on |
Bronze Member Username: Help_2
MN
Post Number: 11 Registered: Dec-04
| Posted on Monday, December 13, 2004 - 01:05 pm: |
You can get it repaired... Not something you should attempt yourself. If it costs too much to fix, toss it |
