Home > Message Board > Car Audio > Amplifiers > Archive through December 14, 2004 > Wire gauge
Author Thread: Wire gauge
Username: Rzarector
Coquitlam, Bc
Post Number: 25
someone at the audio recommended using 0 gauge wire from batter to distro block fir 2 MRD-M501's
i was like ok untill i saw a roll of 2 gauge today which looked massive ..so is this guy full of crap or do i really need to use this giant wire
Username: Glasswolf
NorthWest, Michigan
Post Number: 6355
MRD-501
550W x 1 RMS (2ohm;@14.4V 1% THD+N)
425W x 1 RMS (2ohm;@12V 1% THD+N)
225W x 1 RMS (4ohm;@12V 1% THD+N)
V12 AccuClass-D amp
figure at 2 ohms, the amp will draw about 46A of current at full output
that's 92A of current total for two of them.
at that amount of current, you're good using 4ga cable for up to a 20 foot run.
no need for 2ga unless you add a third amp.
yes 2ga and 0ga cable are both rather huge.
not much fun to route through a firewall and under trim panels either.
Home > Message Board > Car Audio > Amplifiers > Archive through December 14, 2004 > Wire gauge [ « Previous ] [ Next » ]
