Home > Message Board > Car Audio > Amplifiers > Archive through December 14, 2004 > What amp?
Author Thread: What amp?
what would be the best amp to buy to power one 12" solobaric L5 subwoofer?
Username: Glasswolf
NorthWest, Michigan
Post Number: 6314
do you have the S12L5 already?
what is the voice coil configuration?
dual 2 ohm? dual 4 ohm?
no i do not have it yet im askin like if bought one what amp would i need to go with it? it will probably be 4 ohm i dont know about the voice coil configuration
Username: Glasswolf
NorthWest, Michigan
Post Number: 6341
ok the sub comes in two versions.
what you'll want, for a single sub is the dual 4 ohm coil version.
this will gie you a 2 ohm load to a mono amp when its all wired up.
then you want a mono amp that puts out around 600 wats RMS x 1 @ 2 ohms.
the Kicker KX600.1 is a good choice
If you plan to add a second S12L5 later, then get the Kicker KX1200.1
that will give you 600 watts to one sub, or 600 each to two of them.
the sub comes in dual 2 ohm and dual 4 ohm coil versions.
again, you want the dual 4 ohm version.
that's two coils, 4 ohms each, for each sub.
i just looked at the kicker kx600.1 and its like 350.00 and i only have like 200 to spend on an amp so is there any other kind that may be cheaper to power one like a different name brand besides kicker or something?
Username: Glasswolf
NorthWest, Michigan
Post Number: 6351
JBL BP600.1
Home > Message Board > Car Audio > Amplifiers > Archive through December 14, 2004 > What amp? [ « Previous ] [ Next » ]
