Thread: Help with amp frequency.... |
| Posted on Friday, December 10, 2004 - 09:12 pm: |
I have one HX2, and a 250x2 rockford amplifier..... I have it set on LP, but there is the frequency knob on the back.... It goes from 50hz-200hz what should I have that set on? I listen to mostly R&B and Rap..... thanks |
Silver Member Username: Carguy
Post Number: 815 Registered: Nov-04
| Posted on Friday, December 10, 2004 - 11:38 pm: |
Hey dman, for the frequency control, 50hz - 80hz will give you lower soft bass, wherelse 100hz - 200hz will give you harder bass that shakes your trunk more. It all depends on the music. If your song contains lot of low drum beats, then set it to 80hz or loser. If however, your music contains lots of higher drumb/guitar sounds, then 100hz - 200hz will be good.
NorthWest,
Michigan
Post Number: 6234 Registered: Dec-03
| Posted on Saturday, December 11, 2004 - 12:06 pm: |
yeah I'd go between 60-80Hz see what sounds good to you
