Home > Message Board > Car Audio > Amplifiers > Archive through December 14, 2004 > What size amp shoud i have? need to ...
Author Thread: What size amp shoud i have? need to know
Username: Spoon17811
I have 2 12 inch subs 1200 watts peak, 350 watts RMS. I also want to get cd player and 2 6*9's and 2 3inch speakers. What size amp should i use?
Username: Carguy
Post Number: 816
Hey David, that'll depend on what you want to with it. Do you want to power your subs or all of the speakers in your car?
For the subs, you'll need to get at least 500W rms amp that's 2ohms or 1ohm stable.
If you're planning to power your 6x9's and 3inchers, then a 4 channel amp would be a good idea. Look for something that's 75w rms x 4 at least.
cooterman
What size amp do i need if I want to power a 15 inch jl sub
Username: Carguy
Post Number: 832
Hey Cooterman, that'll depend on your sub. Which model is it?
Home > Message Board > Car Audio > Amplifiers > Archive through December 14, 2004 > What size amp shoud i have? need to ... [ « Previous ] [ Next » ]
