Thread: Coustic 400 watt amp |
New member Username: Jmoney12rr
Post Number: 1 Registered: Dec-04
| Posted on Friday, December 10, 2004 - 05:00 pm: |
I just got my new 12" kicker comp Vrs today and we hooked them up to my friends 400 watt coustic amp which he is sellin me a little bit later, well anyways when we hooked them up they were hittin real hard and then all the sudden they got real quite and the amp protection light came on and then went back off..i put my ear next to the subs but i didnt hear any distortion..he has a stock battery so could that be why the light kept going on and off? |
Silver Member Username: Oleg
Santa Monica,
CA
Post Number: 191 Registered: Nov-04
| Posted on Monday, December 20, 2004 - 12:03 am: |
I forget, are comp vr's DVC or SVC? also, did you get them with 2 or 4ohms/coil? I haven't heard of coustic amps, but is it 2ohm stable? You may very well be running it at 1ohm. That'll cause a 2ohm stable amp to overheat really fast. If you keep doing that, the amp will blow quick. Also, if those 400W subs are hitting hard with a 400W amp(peak?) and are hitting hard, the amp may be clipping like none other!
NorthWest,
Michigan
Post Number: 6653 Registered: Dec-03
| Posted on Monday, December 20, 2004 - 10:19 am: |
CVRs are dual 2 or dual 4 ohm coustic's amps are 2 ohm stable, or if 2 channel, 4 ohm stable when bridged. coustic rates their amps with RMS power. always have to my knowledge. I've sold and used their stuff since the late 80s good entry level stuff the CVRs are rated for up to 400wRMS each
Santa Monica,
CA
Post Number: 196 Registered: Nov-04
| Posted on Monday, December 20, 2004 - 11:13 am: |
Cool, thanks Glass. So how do you have them wired, Joey? |
Post Number: 3 Registered: Dec-04
| Posted on Monday, December 20, 2004 - 10:18 pm: |
I have them wired in parallel givin me a load of 2 ohms. The friend who has this amp has 2 12" audio bahn q flames hooked up to that amp, but i know for a fact when he hooked up my subs to that amp he bridged them, so is that why it was doing that? |
Santa Monica,
CA
Post Number: 201 Registered: Nov-04
| Posted on Monday, December 20, 2004 - 10:34 pm: |
Well, that seems iffy...either take the subs out and look, or ask your friend for sure. The only way you'll get a 2 ohm load out of those subs is if they're dual 2 ohm wire in series-parallel. Seriesed the coils and paralleled the subs. Did your friend do that? If it's parallel-parallel with 2ohm DVC, you get .5 ohm load, and 1ohm load with 4ohm DVC. See how they're really wired and compare to what I've said. |
Post Number: 5 Registered: Dec-04
| Posted on Monday, December 20, 2004 - 10:48 pm: |
the coils are parralled for sure, i did that myself. When we hooked them to the amp though, he connected them so i dont know how he did it, i know it was a really weird way of doing it though. It was like the left positive on the amp goes to the left positive on the sub and the left negative went to the right sub. When he was doing that i asked him if he knew what he was doing and he said yea thats how his q flames were hooked up.That may sound crazy but i cant rememeber exactly how it went. |
Post Number: 6 Registered: Dec-04
| Posted on Monday, December 20, 2004 - 11:12 pm: |
oh yea, there dual 4 ohms |
Santa Monica,
CA
Post Number: 205 Registered: Nov-04
| Posted on Monday, December 20, 2004 - 11:37 pm: |
That doesn't seem seriesed to me at all. He would've been right in knowing what he's doing if the amp was 1ohm stable, but it's not. Since you paralleled the coils, you'll need to series the subs to get a 4ohm load and then bridge the amp. To series the subs, if the amp has 2 channels: 1. Connect pos of ch. 1 to pos of sub 1 2. Get another segment of speaker wire and run it from the neg terminal of sub 1 to pos terminal of sub 2. 3. Connect neg of ch. 2 to neg of sub 2 terminal. Actually, this is the absolute only way to do it, except if you want an 8ohm load, where your subs will hardly move. So problem solved?
Post Number: 7 Registered: Dec-04
| Posted on Monday, December 20, 2004 - 11:41 pm: |
yea, problem solved. i know now that it was because the amp wasnt stable, i was kind of scared cause it thought it was clipping so, i can fix this now. Thanks alot man. I appreciate it |
Santa Monica,
CA
Post Number: 206 Registered: Nov-04
| Posted on Monday, December 20, 2004 - 11:53 pm: |
Yeah, pretty sure it was clipping. Let me know if it sounds alright with less current. With a 4ohm load, the amp is not going to provide a lot of current, so it's important not to push the amp below its limits @ 4ohms. Consider getting a 1ohm stable amp. |
Post Number: 8 Registered: Dec-04
| Posted on Tuesday, December 21, 2004 - 04:02 pm: |
i have another question, i have an 8 gauge wire just laying around, but im gonna get a 4 gauge. Can i just use the fuse holder from the 8 gauge wire on the 4? |
Santa Monica,
CA
Post Number: 208 Registered: Nov-04
| Posted on Tuesday, December 21, 2004 - 07:05 pm: |
Depends if the fuse holder has large enough holes to accept 4ga |
