Home > Message Board > Car Audio > Amplifiers > Archive through December 14, 2004 > I know running 0 gauge wire is overki...
Author Thread: I know running 0 gauge wire is overkill...but
Username: Erik123456
Arlington, Tx
Post Number: 221
does it have any negative effects?
Im going to be running around 1200 watts
Username: Solacedagony
New Jersey
US
Post Number: 135
I don't believe so. It's just more expensive. You should probably be running at least 2 gauge for 1200W anyway, so it's no biggie.
Username: Glasswolf
NorthWest, Michigan
Post Number: 6206
just harder to run it.
once it's all in place, there aren't any drawbacks to it, no.
you can always split down to smaller cable for short runs to amplifiers with a distribution block.
Home > Message Board > Car Audio > Amplifiers > Archive through December 14, 2004 > I know running 0 gauge wire is overki... [ « Previous ] [ Next » ]
