Home > Message Board > Car Audio > Amplifiers > Archive through December 09, 2004 > What power guage?
Author Thread: What power guage?
guest
i have a 97' civic 4 door. i'm puting a 551s power amp and don't know what guage use. i plan to put the amp in the trunk.
Username: Carguy
Post Number: 770
For amps around 1000W, you can use 4 gauge, anything higher, try 2 or 1gauge.
If however your amp is under 500W, 8gauge is fine.
guest
these are the specs of the wattage.
140 watts RMS x 2 at 4 ohms
275 watts RMS x 2 at 2 ohms
550 watts RMS x 1 bridged output at 4 ohms
since it is over 500 i will need the 4 guage right, and what type of fuse should i use, a friend mine told me to use 80 but don't know if he is right.
Username: Carguy
Post Number: 771
For your amp, I wouldn't go any higher than 60A. In fact, 50A is all you really need.
guest
ok, thanks for your help Isaac. :-)
Username: Glasswolf
NorthWest, Michigan
Post Number: 6144
http://www.the12volt.com/info/recwirsz.asp
Home > Message Board > Car Audio > Amplifiers > Archive through December 09, 2004 > What power guage? [ « Previous ] [ Next » ]
