Thread: Quick speaker to amp question |
Bronze Member Username: Nbacker
Post Number: 11 Registered: Jul-04
| Posted on Wednesday, December 08, 2004 - 12:50 am: |
I finally, finally picked up the 2 sets of speakers that I've wanted and talked about for the past 3 months. I got the set of 6.5" Infinity Kappa speakers that push 75w RMS and a set of 6x9" Kappa's as well that push 110w RMS, and I am going out tomorrow to pick up an amp for them. I am just curious if you guys have any suggestions as to what amp I should look into getting. I want a 4 channel amp so I can push all 4 speakers on a seperate channel so I can get them at 4 ohms each. I'm looking at a price range of about 3-400 dollars (4-500 canadian dollars). Any suggestions on a good amp for these speakers that is a 4 channel? I'll probably most likely need around a 100-125w RMS x 4 channel amp, am I right? Or less, if that's alright? Would be much appreciated. Thanks alot.
Silver Member Username: Carguy
Post Number: 753 Registered: Nov-04
| Posted on Wednesday, December 08, 2004 - 10:45 am: |
Hey Taylor, I purchased Audiobahn A4125HCT 4 channel amp. It's rated 125W rms into 4ohms, 250W rms @2ohms and 500W @1ohm. Been using the amp for couple of months now and still working great. If you want other brands, Try RF/Kicker/Alpine. They have 4 channel amps that should meet your budget. Don't buy amps that's less than 50W x 4. Not worth the money. |
