Home > Message Board > Car Audio > Amplifiers > Archive through December 09, 2004 > Installation
Author Thread: Installation
Username: Reddy
Medina, Ohio
Glasswolf;
Have a Ford Model A, need wiring instructions how to install,( MTX Thunder 250x & Bazooka base tubes ). Units will be install under rear seat,not easily accessible.Does power come directly from battery or ignition switch??
Thank You
Username: Carguy
Post Number: 737
Well it looks like glass is busy tonight so I'll see if I can help.
You have to buy a amp wiring kit and install it either yourself or have a prof do it. It comes with full instruction.
Walmart sells them cheap.
Here's a summary. You connect the red power wire with fuse,to the battery and wire it on the same side as your battery. Run it along the door frames. For ground, under your back seat, sand/grind off the car chassis and use ground wire, no longer than 18". For remote wire, your HU should have it either taped up or hanging loose. Run a wire to that on HU, and have it together with your power wire.
Your amp will need pos, ground and remote wires. For your rca cable, run it on the opposite side of the power wires. For example, if your battery is on your left, then wire the rcas on your right.
This should help minimize noise pickup.
Connect all wires properly and you should be okay.
Home > Message Board > Car Audio > Amplifiers > Archive through December 09, 2004 > Installation [ « Previous ] [ Next » ]
