Thread: Which would be better |
New member Username: Luc89
Post Number: 1 Registered: Dec-04
| Posted on Tuesday, December 07, 2004 - 10:26 pm: |
Im goin to purchase 4 12" solo baric L7 subs. (2 for a supercab F-150 and 2 for a Lincoln LS) and Ive been looking at the Kicker KX2500 and the KX1200 and dont know which would be better. I dont want to kill myself with to much power, but i dont want it to sound shallow. feed back will be greatly appreciated. |
Silver Member Username: Carguy
Post Number: 739 Registered: Nov-04
| Posted on Tuesday, December 07, 2004 - 11:43 pm: |
Hey Adam, KX1200 has a lot of power. It should be enough to make your chest pound. Unless you like going deaf, I wouldn't go more than 1200W rms. Anyhow, before you can even get that much power, you'll need HO alternator, caps, power wires etc. upgraded in your cars. |
Post Number: 3 Registered: Dec-04
| Posted on Wednesday, December 08, 2004 - 12:01 pm: |
Thanks Isaac, i know ill need all that stuff to, but the amp is $800, is there a place where i can get it cheaper, and my friend runs the same subs with a memphis 1000 and he loves it and the the price to, $350. But i wanna run a kicker amp with the subs, so is there ne way possible to get it cheaper. |
Post Number: 759 Registered: Nov-04
| Posted on Wednesday, December 08, 2004 - 01:38 pm: |
Hey Adam, on eBay.com, Kicker KX1200 is $389 brand new or $250 refurb.
Post Number: 4 Registered: Dec-04
| Posted on Wednesday, December 08, 2004 - 06:49 pm: |
Thanks again Isaac, found it on eBay.com, but i dont use ebay unless i can go and personally see the product. |
