Thread: Which amp |
New member Username: Bass_crazy
Odessa,
Mo
U.S
Post Number: 7 Registered: Nov-04
| Posted on Tuesday, December 07, 2004 - 08:08 pm: |
i have two bazooka 12in subs the rms is 225 and peak is 400W what type or watts. of mono amp do i need? |
Silver Member Username: Carguy
Post Number: 741 Registered: Nov-04
| Posted on Tuesday, December 07, 2004 - 11:57 pm: |
Hey bass crazy, that's not much power for a sub. Anyhow, you can try any 200W - 300W rms amps from RF/Kicker/JL/JBL/Audiobahn/MTX. The cheapest one on eBay is MTX6500D. It's 500W rms @2ohms.
Odessa,
Mo
U.S
Post Number: 8 Registered: Nov-04
| Posted on Wednesday, December 08, 2004 - 05:05 pm: |
would 300w or 500 what rms blow the subs thowe |
Post Number: 767 Registered: Nov-04
| Posted on Wednesday, December 08, 2004 - 05:59 pm: |
Hey Bass, as long as you have self control, it won't blow your subs. Besides, its better to get stronger amp over subs cause most amps will distort never their max setting. This way you'll be able to get clean 225W easily without clipping.
Odessa,
Mo
U.S
Post Number: 9 Registered: Nov-04
| Posted on Wednesday, December 08, 2004 - 08:26 pm: |
thinks ill try it hopefully i dont turn it up to lowed then |
