Home > Message Board > Car Audio > Amplifiers > Archive through December 09, 2004 > Which Is The Best?
Author Thread: Which Is The Best?
Username: Counterstrike
Post Number: 24
What would be the best amp to buy for 2 2ohm 500 rms watt subs. What would be the best amp to buy but not going over $300? And there 15 inch alpine subs if theres certain amps that go better with certain subs.
Username: Carguy
Post Number: 706
You can try JL/JBL 600.1/Audiobahn 2300HCT/MTX 6500D. I think RF/Kicker amps might be above $300.
Post Number: 25
is it better to get a 2 channel amp over a mono??
Post Number: 26
now with 2 channel amps (audiobahn A2300HCT) lets say the rms is 600 does that mean it can go 600 rms watts to one channel and 600 to the other or is it split in 300 rms watts a channel?
Username: Carguy
Post Number: 722
Hey counterstrike, that's 600W rms per channel. There's not much difference between 2 channel and mono amps. All you're trying to do is match the power of the amp to the speakers.
What's good about 2 channel amp is that, it can be bridged into mono and get more power.
Username: Flyfishin4trout
Park City, UT
Post Number: 34
The biggest difference is power consumption. A two channel amp is a class a/b amp which uses more power. A mono amp is a class d amp which consumes much less.
Home > Message Board > Car Audio > Amplifiers > Archive through December 09, 2004 > Which Is The Best? [ « Previous ] [ Next » ]
