Home > Message Board > Car Audio > Amplifiers > Archive through December 09, 2004 > Just a couple basic questions...
Author Thread: Just a couple basic questions...
Username: Lostnconfused
Far Far Away, I Forgot
Post Number: 10
1. What is the purpose of/what should my subsonic filter be set to?
2. What range is best for the LPF when listening to metal?
Thanks!
Username: Carguy
Post Number: 693
Hey Mallory, for the subsonic filter, it's usually set around 20hz. Anything below this, you won't be able to hear. If you haven't experienced any subwoofer movement problem, then you can either set it at default, or turned off.
For listening to metal, you can set LPF anywhere from 70hz - 120hz. Most metal musics do not contain heavy bass.
Just remember, higher hz setting will cut off low bass from your subs and vise versa.
Username: Glasswolf
NorthWest, Michigan
Post Number: 6094
a subsonic filter blocks frequencies below it's set point from being produced.
this is used for ported boxes to prevent the subs from loss of damping below the tuned frequency which will damage your subs.
the SSF is usually set at 20Hz, or one octave below the port tuned frequency of your sub enclosure.
a SSF is not required for a sealed box but will prevent wasted power trying to produce notes you can't hear anyway.
the LPF will vary based on subs, car, power, etc..
usually between 60-80Hz
Username: Glasswolf
NorthWest, Michigan
Post Number: 6095
most metal doesn't have a lot of bass? lol what kind of metal do you listen to?
try some Ozzy, Sepultura, Slipknot, Metallica, or Dead Pool.. those are just a few of the lighter choices in the metal world with some pretty heavy basslines.. It's just a different sort of bass than hiphop.. usually a driving bass guitar line as opposed to an 808 or a kick drum or a synth.
Username: Carguy
Post Number: 698
Yea I know I know, I'm not a metal listener.
Somehow when people say metal, I picture guys screaming their heads off knocking down speakers... :-)
Username: Glasswolf
NorthWest, Michigan
Post Number: 6098
hahaha
some metal I like, some I find droning and irritating. It totally depends on the band. I have a friend who's a total metalhead though. I consult her for details on what's good.. lol
Username: Glasswolf
NorthWest, Michigan
Post Number: 6099
PS Way back when, we used to keep a Pantera CD in the store, just to crank up on the display board to drive out annoying customers at the shop.. hahaha
Post Number: 11
Mmmmmmmmmmmmm.... Pantera. Yea I find most metal songs I listen to hit harder then most techno and some rap lol; if not harder, The subs hit at long low durations and it rattles your mind-I love it. A band I like a lot that I recently have stumbled upon is Children Of Bodom; they are a mix of old rock & roll and nu' metal. A good CD of theirs is "Follow the Reaper" and the Live in Japan CD is just... amazing they truly have talent.
Help2
I love metal...but I listen to just about
everything...
Check out Opeth if youve never heard them...
its progressive death metal with some acoustic
guitars stuck in there to really confuse ya.
The lead singer can death yell and sing normally
in the same song...but it fits for some reason.
great stuff.
Username: Solacedagony
New Jersey
US
Post Number: 118
The guys in Children of Bodom are amazing guitarists. Opeth as well. If you like the lighter stuff, CoB's guitarist is in a band called Sinergy I believe. Female vocalist and whatnot.
aim me at solacedagony if you wanna talk metal ;)
Username: Glasswolf
NorthWest, Michigan
Post Number: 6111
I used some white zombie and rob sombie tonight when I was setting up an infinity basslink.. good stuff there too
Username: Glasswolf
NorthWest, Michigan
Post Number: 6112
Zombie that is.. my little finger doesn't like hitting the Z key lately.. hurts.
haha I sliced across the tip of my finger workin on a system install.. how annoying. actually tore up my left hand a few places pretty well.
Username: Carguy
Post Number: 715
Are you sure you weren't having flashbacks of your "metal" band days?
Home > Message Board > Car Audio > Amplifiers > Archive through December 09, 2004 > Just a couple basic questions... [ « Previous ] [ Next » ]
