Home > Message Board > Car Audio > Amplifiers > Archive through December 09, 2004 > Is it possible to run two remote wires?
Author Thread: Is it possible to run two remote wires?
Username: Klone420
Post Number: 17
How can I run 2 remote wires from the harness of my pioneer DEH-1600 to 2 amps? I've got two amps in the back that are bridged so they only need one wire between them now I want to hook up a third amp (Kenwood KAC-424) to run the tweeters. How can I do this?
Username: Jeremyc
Kunsan Afb
South Korea
Post Number: 204
Just splice into the wire that is all ready back there. No need to run a diffrent wire. I perfer the sodder / shrink tube method. However you could do a simple crimp conector and it should be fine.
Username: Glasswolf
NorthWest, Michigan
Post Number: 6069
If you're running three or more devices from a single remote trigger line, consider using a relay to boost current for the circuit. This will prevent damage to the head unit.
www.the12volt.com has diagrams for wiring relays for this.
Home > Message Board > Car Audio > Amplifiers > Archive through December 09, 2004 > Is it possible to run two remote wires? [ « Previous ] [ Next » ]
