Home > Message Board > Car Audio > Amplifiers > Archive through December 14, 2004 > Low wattage
Author Thread: Low wattage
Username: Muzzle_monkey
could you use a low watt amp for a high watt subwoofer and still make good sound? thanks for any amswers you may have
Username: Carguy
Post Number: 657
Yes you can use it, but depending on how weak the amp is compared to the sub, it might not produce the desired result.
Username: Glasswolf
NorthWest, Michigan
Post Number: 6053
you can, if ya do it right.
the enclosure can make up for the lack of power to an extent, as can the type of vehicle, driver positioning, etc.. within reason.
I mean you won't get car shaking bass out of an 18" sub with 25 watts or anything but being reasonable, you can compensate for lower power with good system design.
Username: Fryguy
Nova Scotia
Post Number: 413
It will still sound fine but it won't be loud. Loud = power and a higher efficiency speaker does a better job at producing sound with the same amount of power.
Home > Message Board > Car Audio > Amplifiers > Archive through December 14, 2004 > Low wattage [ « Previous ] [ Next » ]
