Thread: Sealed or ported?? |
New member Username: Banco
Post Number: 4 Registered: Nov-04
| Posted on Friday, December 03, 2004 - 02:27 pm: |
Hey, i was wondering what was better, a sealed or ported box for 2 10inch xenon phoenix gold subs ?? thanks dudes
New member Username: Sporttruck1992
Somerset,
Ky
Post Number: 2 Registered: Dec-04
| Posted on Saturday, December 04, 2004 - 05:43 pm: |
well that pends on how you want them to sound? I had 2 12 kicker comp c12a in a ported box and it sounded ok but then I made an sealed box and they hit harder well I got some new subs and I would definiately go with sealed |
NorthWest,
Michigan
Post Number: 6076 Registered: Dec-03
| Posted on Sunday, December 05, 2004 - 01:03 pm: |
first, determine their EBP. This determines what your subs are best suited for. Efficiency Bandwidth Product (EBP) EBP = Fs / Qes 50 or less = best used in a sealed enclosure. 50 - 90 = flexible enclosure options. 90 or greater = best used in ported enclosure. If the subs are suited to either box type, then it's up to you and what sort of sound you're after. more on box types: http://www.jlaudio.com/tutorials/magic/index.html
