Home > Message Board > Car Audio > Amplifiers > Archive through December 09, 2004 > Audiobahn ALUM12Q
Author Thread: Audiobahn ALUM12Q
Username: Brett2387
Burlington, WI
United States
I'm going to install one Audiobahn ALUM12Q sub. 1000 watt RMS and 2000 watt MAX. What amplifier would be best?
I have another question...why is there high pitched buzzing sound when I turn the gain up on the amp and gets louder as I accelerate?
I need advice please...
Username: Djeter108
leave the gain down. no more than half way. you'll mess ur subs. trust me
Username: Brett2387
Burlington, WI
United States
I dont have the sub installed yet...the buzzing comes from the speakers. but does anyone know what amplifier i should buy for the ALUM12Q?
Username: Carguy
Post Number: 632
Hey Brett, the amp will depend on your budget. Read one of my posts on here. I listed some examples of the amps for your sub.
The buzzing noise is from your rca cables being too close to the power wires or you have a bad ground cable.
To fix it, make clean ground wire to car's chassis. Use shielded directional rca cable for the amps.
In case you can't find the post, try RF/Kicker/JL/JBL/Audiobahn 4125HCT/2300HCT/MTX etc.
Username: Brett2387
Burlington, WI
United States
How far apart should the RCA cables be from the power wires? I have Tsunami twisted RCA cables to the amp i have now. Are those good enough?
Username: Brett2387
Burlington, WI
United States
Would an Audiobahn A1300HCT or A1500HCT be good?
I was also looking at Kicker...what amps are good from Kicker?
Username: Carguy
Post Number: 640
Hey Brett, you'll know soon enough if your rca cables are good. If you hear any engine/power noise in your speakers, it means you need to get shielded directional rca cable.
Run the cables on the opposite sides of your car. If your battery is on your right, then rca on your left and vise versa.
Audiobahn A4125HCT and 2300HCT are the only 2 models that's been tested. If you're looking at Kicker, try KX600.1, and KX1200.1 amps. RF also makes similar amps too, RF T10001BD.
Username: Taylornuts
Wichita, KS
Post Number: 19
Hey Brett try and make your ground closer to your amp I think 18 inches or less it might take car of that noise.
Home > Message Board > Car Audio > Amplifiers > Archive through December 09, 2004 > Audiobahn ALUM12Q [ « Previous ] [ Next » ]
