Thread: Is This a Good Brand?? |
Bronze Member Username: Counterstrike
Post Number: 22 Registered: Nov-04
| Posted on Thursday, December 02, 2004 - 09:05 am: |
i was just wondering if audiobahn make good amps, i need an amp that will power 2 500rms watt subs but i only have about 300 to spend, anyone have any idea. thanks a lot |
Silver Member Username: Jeremyc
Kunsan Afb South Korea
Post Number: 199 Registered: Jun-04
| Posted on Thursday, December 02, 2004 - 12:34 pm: |
I don't care for them, and alot of the the other guys in here don't either. However a few people have them and like them. My sugestion if for you to save a little more and get something better. I have heard alot of good coments about JBLs refurbished amps, and you can get them for a really good price. |
Silver Member Username: Carguy
Post Number: 608 Registered: Nov-04
| Posted on Thursday, December 02, 2004 - 12:41 pm: |
Hey Counterstrike, I am one of the few that owns Audiobahn amp. Let me tell you for the price I paid, I'm getting great value. If bass is what you want at a reasonable price, then get A4125HCT or 2300HCT models. If you're lucky, you can set the remote bass control half way. Go read up on those 2 model amps. They are actually good. If you want even a cheaper amp, try MTX 6500D. They go for $75 - $120 on eBay. It's 500W rms at 2ohms, and 775W at 14.4v. Unlike other cheap amps, MTX delivers. I wouldn't try refurb amps unless the shop is local. |
