Thread: What amp/s for my 2 15's? |
J Brower Unregistered guest |
| Posted on Tuesday, November 30, 2004 - 09:55 pm: |
Hey guys. Ive got two 15's precision power woofers. They are 1000rms a piece with a 2500watt maxx a piece. They are 8 ohm subs. Ive got them in a ported box in my car already, but nothing to power them with. What should I get? I want to stay as cheap as possible price wise. I was looking at getting two 1600w maxx amps on ebay that run 800rms bridged. Thanks, Jeff |
Bronze Member Username: Oleg
Santa Monica,
CA
Post Number: 49 Registered: Nov-04
| Posted on Wednesday, December 01, 2004 - 05:09 am: |
Which amps were you looking at exactly? It sounds like you were looking at the cheap stuff. Having 2 15's you'll need something a bit more serious. What's yor budget? 15's are less sensetive than 12's or 10's so they required more power, plus they're 8ohms? I hope they're DVC's so you can wire them down to 2ohms. So let me know the budget. |
j brower Unregistered guest |
| Posted on Saturday, December 04, 2004 - 11:35 pm: |
sorry for no reply. I bought a 5000 watt amp with 1750 watt rms. Im going to tak eit to my local car audio shop to have them help me hook it up right. I just want to get it done where i know its right so I dont have to worry about it anymore. Thanks for your help. Jeff |
Santa Monica,
CA
Post Number: 97 Registered: Nov-04
| Posted on Sunday, December 05, 2004 - 11:44 am: |
Cool. What kind of amps is it? Be sure to post it so everyone can take this amp into consideration, if it works well of course. Thanks man |
