Thread: JL subs |
break the silence Unregistered guest |
| Posted on Tuesday, November 30, 2004 - 06:11 pm: |
I am purcasing the JL audio 8W7 because of lack of room in the back and i need an amp that can put out around 400 watts at 3 or 1.5 ohms. is there another amp besides JL amps that i could run at 3 or 1.5 ohms? |
Bronze Member Username: Oleg
Santa Monica,
CA
Post Number: 55 Registered: Nov-04
| Posted on Wednesday, December 01, 2004 - 05:35 am: |
Checkout Audiobahn, JBL class D amps. |
Silver Member Username: Solacedagony
New Jersey
US
Post Number: 108 Registered: Oct-04
| Posted on Wednesday, December 01, 2004 - 09:31 am: |
A JL Audio 500/1 would be a good amp for that, but if you really don't want to run a JL amp on that, Phoenix Gold, JBL, and some others will run that load. Also, I believe any amp that runs 1 ohm stable would be able to run that 1.5 ohm load. Don't quote me on that. |
Santa Monica,
CA
Post Number: 59 Registered: Nov-04
| Posted on Wednesday, December 01, 2004 - 01:45 pm: |
Jake is right, if the amp is 1ohm stable, it'll be able to run at anything above that as well. Do quote me on this one. Everyone speaks exteremly highly of that JBL 1200.1 amp, so try it and I don't doubt you'll enjoy it. |
| Posted on Wednesday, December 01, 2004 - 04:08 pm: |
ok thank you |
New member Username: Swampmice
Fort Worth,
TX
US
Post Number: 6 Registered: Dec-04
| Posted on Wednesday, December 01, 2004 - 05:31 pm: |
Any help would be welcomed. I was given a JL Audio 12W7 Sub. I am looking for an Amp to push the speaker. I have two MTX 6001 amps already. Will this be good or should I go a different route? I understand that the amp has to a be a 1000/1. is that true? By the way thanx Oleg Ni for the help concerning biamping the sub. |
Fort Worth,
TX
US
Post Number: 8 Registered: Dec-04
| Posted on Wednesday, December 01, 2004 - 05:33 pm: |
Sorry posted in nthe wrong thread! |
