Home > Message Board > Car Audio > Amplifiers > Archive through December 02, 2004 > What Is Fb?
Author Thread: What Is Fb?
big o
I just got a Kicker L7 "12 and on one of the recommended vented boxes it says: Fb=37Hz. I'm rookie and was hoping someone could help me out.
Help2
Its the tuning frequency of the box they recommended.
If you follow the plans, thats what the port
will be tuned to, meaning that will be the center
frequency the sub will play at.
big o
so should i set my bass boost at 37Hz?
Username: Carguy
Post Number: 543
No guy, if you build the box according to the spec, the box port will give you 37Hz.
Username: Glasswolf
NorthWest, Michigan
Post Number: 6017
a ported box has a tuned frequency. this is where the box is most efficient and puts out the most bass with the least power essentially.
the tuned frequency is based on enclosure volume, and port cross-sectional area.
If you want a pre-made box for an L7 try www.bigdogcaraudio.com
they carry several I believe.
all built to spec for those subs
Home > Message Board > Car Audio > Amplifiers > Archive through December 02, 2004 > What Is Fb? [ « Previous ] [ Next » ]
