Thread: When Bass Hits Hard, Subwoofer Amplifier Light Dims and Components do not play until bass calms ... What Can Be The Problem ??? |
Silver Member Username: Maxkilla
Malta
Post Number: 132 Registered: Jan-04
| Posted on Monday, November 29, 2004 - 06:06 pm: |
I have a problem when i play bass at high volume the components don't play music. Its like they don't have enough power to play and bass takes over all. What can be the Problem ? |
fe-fi-fark-u Unregistered guest |
| Posted on Monday, November 29, 2004 - 07:24 pm: |
Power wire Gauge? total wRMS? alt?
Silver Member Username: Joe718
Brooklyn,
NY
Post Number: 272 Registered: May-04
| Posted on Monday, November 29, 2004 - 07:28 pm: |
U need a way bigger alternator. use this site to find one that fits the make of your car http://www.4alterstart.com/ |
Malta
Post Number: 133 Registered: Jan-04
| Posted on Tuesday, November 30, 2004 - 06:19 pm: |
mmm when the car is idle it does this aswell. Amplifiers Boss Pd-4000 1200Watts RMS, Hifonics Zeus ZX4000 - 200 RMS Speakers - Infinity Kappa Perfect 6.1 Subwoofer - Power Aqoustik Mofo 12" in Ported custom Box Pd-4000 - 4 guage Directed wire Hifonics - 8 guage wire Battery - Exide Maxima 9000 Alternator - Stock 60Amps |
Silver Member Username: Solacedagony
New Jersey
US
Post Number: 107 Registered: Oct-04
| Posted on Tuesday, November 30, 2004 - 10:48 pm: |
Definately a high output alternator. |
Malta
Post Number: 138 Registered: Jan-04
| Posted on Friday, December 03, 2004 - 09:03 pm: |
Would you change something else ? Is this a nice car audio setup in your opinion ?
