Home > Message Board > Car Audio > Amplifiers > Archive through December 02, 2004 > Need help on picking an amp for my sp...
Author Thread: Need help on picking an amp for my speakers.
Username: Rusio1
Phoenix, Az
I have 2 Fosgate 10" P-1 (400wts) SVC @ 4ohms. I have a real good deal on the table to buy a Planet Audio amp. I'm confused on which one would be the best. These are D-class amps:
VX1400D- max. 1250w, rms 500 X 1 (4 ohms)
VX900D- max. 950w, rms 375 X 1 (4 ohms)
Username: Carguy
Post Number: 508
Hey Anthony, I'd go with VX1400D model. You'll find that once you start cranking up the volume, 375W is not enough.
When you say a good deal, how much are you talking? There are lot of amps besides that.
Username: Rusio1
Phoenix, Az
The cost for the VX1400D is $291 and for the VX900D is $214.
Username: Solacedagony
New Jersey
US
Post Number: 100
If you go on cardomain.com and hit the shop by brand, check out JBL. I would imagine their amps are better quality than the Planet Audio, plus you'll be saving some money. www.cardomain.com. Check out their BP renewed amps, when they have them on there.
Also, they have an MTX renewed up there.
http://www.cardomain.com/shoplist~b~MTX+Audio~t~Subwoofer+Mono+Amps
If you like Orion, they have one as well:
http://www.woofersetc.com/product.asp?0=399&1=705&3=3450
Just wanted to give you some other options, assuming you're not definately set on getting Planet Audio.
Home > Message Board > Car Audio > Amplifiers > Archive through December 02, 2004 > Need help on picking an amp for my sp... [ « Previous ] [ Next » ]
