Thread: JBL LC-A504 |
Bronze Member Username: Jwbulger79
Florida
Post Number: 49 Registered: Nov-04
| Posted on Sunday, November 28, 2004 - 07:27 pm: |
Check this out: http://shop.store.yahoo.com/imezak/lca504.html $65?? Is this amp any good?? JBL's are OK right? Is this their low end amp? Price seems rediculously low. Should the power @ 4ohms quadruple when bridging to 2 channel (eg 50x4 @ 4ohms, Bridged 200x2 @ 4ohms)? This doesnt even triple. I thought I remember reading something about how that can be how to tell if an amp is any good. Thanks ya'll. |
Bronze Member Username: Oleg
Santa Monica,
CA
Post Number: 15 Registered: Nov-04
| Posted on Sunday, November 28, 2004 - 10:03 pm: |
It's funny that you just posted that because I just saw the same amp on ebay for $59. Power at 2ohm is twice as great as at 4ohm. V=IR, where V=voltage(12), I=current, R=resistance(2ohms). I haven't seen the amp before, so couldn't tell you. It's an older model, so that's probably why it's cheaper. |
Florida
Post Number: 50 Registered: Nov-04
| Posted on Monday, November 29, 2004 - 12:50 am: |
Anyone have any experience with this amp? Glass, Johnathan, Damien, Isaac, any thoughts on this one? It seems like we get what we pay for in car audio, but then again I thought JBL made some OK amps. Will this amp be any good for SQ? Thanks. |
