Thread: Sheer Power |
New member Username: Siner1227
Post Number: 1 Registered: Nov-04
| Posted on Sunday, November 28, 2004 - 05:07 pm: |
I'm trying to find a somewhat cheap ($500-$900) amp with alot of power.For me it doesen't really matter how much noise it makes or how clear the sound is I just want the most powerful amp for a reasonable price.What models do u suggest. |
Silver Member Username: Joe718
Brooklyn,
NY
Post Number: 256 Registered: May-04
| Posted on Sunday, November 28, 2004 - 05:32 pm: |
Wow $500 to $900 for an amp is not cheap lol. That leaves alot of possibilities. I always look for the sub first then find an amp to match, unless you already have some subs in mind. If so let us know. There are alot of brands out. But off the top of my head the JL audio 1000/1 will hold damn near every load you can give it from I believe 0.5 to 4 ohms, your looking at like a $610 to $650 price tag. But let us know what subs your using so we can be specific. |
Post Number: 3 Registered: Nov-04
| Posted on Sunday, November 28, 2004 - 06:04 pm: |
I'm looking at getting either 2 Power Acoustik FUBR-12 or 2 Audiobahn AW1200Q. Do u think these are any good? If not what what would be better for arround the same prices as these. |
Post Number: 4 Registered: Nov-04
| Posted on Sunday, November 28, 2004 - 06:40 pm: |
What other good amps are available for a little cheaper($400-$600). |
Silver Member Username: Southernrebel
Monroe,
Louisiana
Post Number: 276 Registered: Mar-04
| Posted on Sunday, November 28, 2004 - 06:56 pm: |
ummm... those wouldnt be my first choice when it come to subs. if you looking to get a really big amp, you'll need a high output alternator as well. how much money do you have to work with? (for the whole system) |
Brooklyn,
NY
Post Number: 262 Registered: May-04
| Posted on Sunday, November 28, 2004 - 07:00 pm: |
For subs go to www.adireaudio.com check out these subs called the shiva they are $125 just a lil more than what you were going to pay for the other subs |
NorthWest,
Michigan
Post Number: 6000 Registered: Dec-03
| Posted on Sunday, November 28, 2004 - 07:03 pm: |
honestly I think both of those subs suck. You also won't need more than 500 watts each for them either. Joseph, $900 isn't "cheap" for an amp, no, but it is reasonable. That's still far below the cost of a number of higher end companies like Brax and Tru. If you want good ubs for SQ and SPL combined, look at two RE triple X fifteens. for SPL only look at the RE MT subs www.reaudio.com Once you choose subs, then look for an amp to drive them, knowing the power you'll need. PS, this should make my 6000th post in 12 months. wow.. not bad. heh
Monroe,
Louisiana
Post Number: 277 Registered: Mar-04
| Posted on Sunday, November 28, 2004 - 07:07 pm: |
congrads glass |
