Thread: How do you bridge a 2 channel amp? |
New member Username: Bass_crazy
Odessa,
Mo
U.S
Post Number: 3 Registered: Nov-04
| Posted on Sunday, November 28, 2004 - 12:50 pm: |
I dont know how to bridge a 2 channel amp so i can wire 1 sub up two it and win i bridge it will get have more power in the amp? and there is a mono button on it will that help too. |
Bronze Member Username: Oleg
Santa Monica,
CA
Post Number: 11 Registered: Nov-04
| Posted on Sunday, November 28, 2004 - 04:56 pm: |
Each channel has a positive and a negative lead. If the amp is bridgeable, then you'll be able to connect your sub to the positive lead of one channel and then negative lead of the other channel. This will probably produce about double the power of 1 channel. Which amp is it? That way we can help you more. |
Santa Monica,
CA
Post Number: 12 Registered: Nov-04
| Posted on Sunday, November 28, 2004 - 04:58 pm: |
Odessa,
Mo
U.S
Post Number: 4 Registered: Nov-04
| Posted on Sunday, November 28, 2004 - 05:13 pm: |
its a older carver amp 90w per channel |
Santa Monica,
CA
Post Number: 34 Registered: Nov-04
| Posted on Wednesday, December 01, 2004 - 01:43 am: |
Find out if it's bridgeable. If so just follow the instructions I've given you and you'll be good to go. |
New member Username: Shit4brains
Australia
| Posted on Wednesday, December 01, 2004 - 05:32 am: |
Do you also have to connect the positive & negative terminal that are not connected to the sub with a wire link? |
Santa Monica,
CA
Post Number: 56 Registered: Nov-04
| Posted on Wednesday, December 01, 2004 - 05:54 am: |
you have to connect the pos and neg to the box's pos and neg and then to the amps pos and neg. |
Silver Member Username: Carguy
Post Number: 565 Registered: Nov-04
| Posted on Wednesday, December 01, 2004 - 11:10 am: |
Whoa Phillips, you don't connect the terminals with a wire link. To bridge most 2 channel amps, take the pos from left channel and neg from the right channel. Use those 2 to connect your sub. Leave the other terminals alone.
Santa Monica,
CA
Post Number: 61 Registered: Nov-04
| Posted on Wednesday, December 01, 2004 - 01:50 pm: |
What's a wire link anyway? |
Post Number: 568 Registered: Nov-04
| Posted on Wednesday, December 01, 2004 - 01:57 pm: |
Not sure, I thought he meant using a wire to physically connect the unused terminals. |
Odessa,
Mo
U.S
Post Number: 6 Registered: Nov-04
| Posted on Wednesday, December 01, 2004 - 09:20 pm: |
it has a mono button on it do i need to push it win a bridge it? |
Santa Monica,
CA
Post Number: 73 Registered: Nov-04
| Posted on Thursday, December 02, 2004 - 02:44 am: |
Isaac? I dunno about any mono buttons on amps. This one's on you. |
