Thread: Help wiring a 4 channel amp |
New member Username: Spellman21
Post Number: 1 Registered: Nov-04
| Posted on Saturday, November 27, 2004 - 05:37 pm: |
I just purchased a 4 channel amp 800 watts bridged max, 2 ohm stable stereo 4 x 85 watts into 4 ohms RMS, 4 x 105 watts into 2 ohms RMS .. I have 4 speakers each with 4 ohm impeadances, and am wondering the best way to wire the speakers with this amp. Wiring them all in parallell gives me an ohm of 1, which i have read is deadly for the amp. Utterly confused in how to wire the speakers. Front 2 in parallell and back 2 in series?= 2 ohms + 8 ohms=10 ohms? is that efficient? Help would be GREATLY appreciated |
New member Username: Lostnconfused
Far Far Away,
I Forgot
Post Number: 3 Registered: Nov-04
| Posted on Saturday, November 27, 2004 - 09:42 pm: |
or just wire a speaker to each channel... |
Post Number: 2 Registered: Nov-04
| Posted on Saturday, November 27, 2004 - 10:20 pm: |
how should i wire each speaker to each channel??? parallell or series? if i do all 4 in parallel than the impedance is 1. if i wire all 4 in series the impedence is 16, and i want to get the most out of my amp. Please help!!!!!!! |
| Posted on Sunday, November 28, 2004 - 09:20 am: |
can anyone help ? |
Bronze Member Username: Jwbulger79
Florida
Post Number: 53 Registered: Nov-04
| Posted on Monday, November 29, 2004 - 09:35 am: |
dont wire series or parallel. just front-left channel to front left-speaker, front-right channel to front-right speaker, etc. no need to get complicated. http://www.bcae1.com/ go to page 107 "system diagrams" on the menu pane on the right side, scroll down to the 4th from last diagram titled "4 channel input" |
Silver Member Username: Carguy
Post Number: 504 Registered: Nov-04
| Posted on Monday, November 29, 2004 - 12:13 pm: |
Hey guy, you have a 4 channel amp so use it to power your front and rear speakers. I'm sure you'll see channel 1,2,3, and 4. Use 1 for front left, 2 for front right, 3 for rear left and 4 for rear right. Keep it simple. Anyways, if you wire the speakers in parallel, you'd be basically turning a stereo sound into a mono! That's not a wise choice.
