Thread: Good amp for less than $250 power 600 X 1 |
need_amp Unregistered guest |
| Posted on Saturday, November 27, 2004 - 02:42 am: |
i am looking for an amp with 600 X 1 rms at 2 ohm. could be 500 to 650 rms range please. |
Silver Member Username: Joe718
Brooklyn,
NY
Post Number: 251 Registered: May-04
| Posted on Saturday, November 27, 2004 - 02:58 am: |
go to www.cardomain.com an look at he jbl bp600.1 You will get a good amp and it runs for like 150 |
| Posted on Saturday, November 27, 2004 - 03:29 am: |
wow, amp looks sweet and perfect power. nice.. if anyone has this amp or know how it is(review) let me know. pros and cons. i would probably buy it on monday. thanks joseph. |
NorthWest,
Michigan
Post Number: 5975 Registered: Dec-03
| Posted on Saturday, November 27, 2004 - 08:38 am: |
the JBL is a great amp for the money. only two things to note: no subsonic filter so if you use a ported box, you'll need to add an RCA level filter from partsexpress (FMOD 20Hz high pass filter) for about $25 secondly, you may want to buy two RCA Y-splitters (2M-1F) because the JBL amps offer 4 RCA inputs on the mono amps, and sending signal to all 4 inputs increases the output of the amp noticeably for some reason. It's just a little trick with those amps that helps them hit a little harder.
NorthWest,
Michigan
Post Number: 5976 Registered: Dec-03
| Posted on Saturday, November 27, 2004 - 08:39 am: |
PS knukonceptz.com has the Y splitters in their interconnect section for about $3 each cheap tricks there.
| Posted on Saturday, November 27, 2004 - 10:03 pm: |
i have subs in sealed so i don't have to worry about subsonic filter(right?). i will buy the y splitter. just to make sure, i have 1 (sub)output coming from headunit, 1 left 1 right. now, i will connect y splitter to (for example) left so now i have 2 left connecter.now,(my question is) do i connect 2 left to 2 left input on amp or 2 left to L and R inputs on amp? i would follow the same for right. thanks glasswolf. |
| Posted on Thursday, December 02, 2004 - 05:16 pm: |
sorry guys, i had to bring this thread again. cardomain has ranout of jbl bp 600. i saw it on sunday and on monday it's all gone. feel like an idiat...anyway, i need a class D 600 X 1 at 2 ohm amp under $200 bucks. thnks |
Silver Member Username: Carguy
Post Number: 622 Registered: Nov-04
| Posted on Thursday, December 02, 2004 - 05:24 pm: |
Hey try other places, I'm sure they have it. Cardomain.com is not the only vendor. MTX 6500D is a powerful amp at a cheap price. Look it up on google. |
| Posted on Friday, December 03, 2004 - 01:01 am: |
thanks issac for u r help. now u tell me what should i get and also which one is most efficiant,good sq, and reliable in long run: 1. Rockford Fosgate 500BD $218.00 2. MTX 6500 D $160. 3. Audiobahn a8000t $201.90 thanks bro. |
| Posted on Friday, December 03, 2004 - 01:09 am: |
forgot the 4th one 4. pioneer GM-D510M $186.00 all class D's |
Post Number: 650 Registered: Nov-04
| Posted on Friday, December 03, 2004 - 09:32 am: |
Hey you have them in the correct order. Use that as your guide. The MTX 6500D was on eBay lastnight starting off at $10.
| Posted on Sunday, December 05, 2004 - 03:23 pm: |
issac thanks. i am looking on ebay everyday to get a deal. i assuming it's efficiant for my car.do u know the fuse rating for this amp? thanks. |
| Posted on Sunday, December 05, 2004 - 03:26 pm: |
i forgot to mention the amp MTX 6500D. |
Post Number: 691 Registered: Nov-04
| Posted on Sunday, December 05, 2004 - 03:59 pm: |
The fuse on the amp is 75A (25A x 3).
