Thread: Whats a good 4 channel amp? |
Bronze Member Username: Donaldl396
Post Number: 16 Registered: May-04
| Posted on Friday, November 26, 2004 - 08:47 pm: |
whats a good 4 channel to power 2 Infinity 6.1 perfects and 2 Infinity 6.5" kappas? I have a Precision Power PC4800 but its just to big to easly mount under my seat. thanks for the help. |
NorthWest,
Michigan
Post Number: 5969 Registered: Dec-03
| Posted on Friday, November 26, 2004 - 10:45 pm: |
try a Kicker KX600.1 perhaps or one of the JBL GTO series amps. under the seat will work but air flow is limited thus so is cooling. not an ideal spot for a class AB amp really.
Bronze Member Username: Bassfreak596
Post Number: 24 Registered: Oct-04
| Posted on Monday, November 29, 2004 - 01:33 am: |
hey but isnt the kicker kx600.1 a mono amp ?? isnt he asking for a 4 channel ? i m saying this cause i have just ordered one kicker kx600.1 for my eclipse sw9122 from woofersetc.com..
Silver Member Username: Carguy
Post Number: 515 Registered: Nov-04
| Posted on Monday, November 29, 2004 - 02:31 pm: |
Yea it's a mono amp, but I think Glasswolf meant check out Kicker brand. They do have 4 channel amp. Have you thought of getting 2 smaller amps instead of one 4 channel? You can then put each amp under driver and passenger seats. Just a thought.
Post Number: 17 Registered: May-04
| Posted on Monday, November 29, 2004 - 10:33 pm: |
Thanks for the help guys. I havent even thought about two small amps, I will look into that angle. I have a friend that has some older Kicker amps and the for the money the work great. Im putting this system in my suburban and Im trying to get a thumpin system and still have space for hauling and everyday family requirements. My PPI 4800 kicks butt, but its about 30" long. Thanks again |
