Thread: Wiring 2 amps Extremely Annoying Problem PLEASE HELP! |
| Posted on Thursday, November 25, 2004 - 11:12 pm: |
Hello, Im tryin to run 2 identical 300w rms amplifiers in my car. I did not read any instructions or plan anything out cuz i thought it would be pretty easy(WRONG!). I have 4 gauge wire running off my battery and then split into two 8 gauge for each of my amps (and a - to the chassy of course). At first nothing worked so i took the remote wires off and bypassed the circuit by connecting the + and - wires. When I do this with either of them they both work fine, however when i try to turn them on together neither of them work. They flash on for about 1/4 of a second then turn off. Why is this???? THANKS |
| Posted on Friday, November 26, 2004 - 02:48 am: |
Oh ya, its on a '91 crx with a good battery but stock alternator |
Silver Member Username: Joe718
Brooklyn,
NY
Post Number: 237 Registered: May-04
| Posted on Friday, November 26, 2004 - 12:02 pm: |
Yeah Hondas do have weak alternators, but i dont think thats yor problem. Well we know your remote wire is no good, since it turns on when you connect it to the battery line. Do you have you amps grounded in seperate places? The amps that tunrs on might have a better ground than the other one. Also make sure your not mounting your amps to metal, if so drill them onto a board. good luck |
Silver Member Username: Carguy
Post Number: 489 Registered: Nov-04
| Posted on Friday, November 26, 2004 - 02:21 pm: |
Hey Jim, you need to get a multi-meter and measure the voltage on the remote wire. If it is dead, then check the fuse box, if they're okay, you could use ignition wire to turn on the amps.
Silver Member Username: Djzavala
Whittier,
Ca
Post Number: 103 Registered: Oct-04
| Posted on Friday, November 26, 2004 - 04:23 pm: |
yeah man, i had the same problem, check your fuses first off before you do anything, it could just be that, try puttin new ones in and see if they work like that. |
